Old 17-03-2006, 09:42 AM   #1
GK
Walking with God
GK's Avatar
Default Throttle Cable Slack!
Hello All,
The throttle cable on the Series 1 wagon seems to have quite a lot of slack in it. I can't see any way of adjustment. Is there? How much slack is it meant to have?
I looked under the intake pipage but couldn't see an adjuster nut and I don't want to take the whole thing off if it's not under there anyway! Is there a way of adjustment at the pedal perhaps?
As always, your help is greatly appreciated.
GK
Old 17-03-2006, 09:46 AM   #2
EA2BA
PM me if you want
EA2BA's Avatar
Not adjustable.
You can temp fix the problem by adding a sort of spacer at the accelerator pedal, but a new cable is what you should do.
I think no slack is wanted, it makes for sluggish response, and you dont get full open throttle either.
Old 17-03-2006, 09:50 AM   #3
GK
Walking with God
GK's Avatar
Originally Posted by EA2BA
Not adjustable.
Not adjustable! You're kidding right! I wonder why they didn't make it adjustable?
I agree with your comment about sluggish performance, I want more of a crisp response, especially at take off.
GK
Old 17-03-2006, 09:57 AM   #4
EA2BA
PM me if you want
EA2BA's Avatar
Even the EA was not adjustable, the only cable adjustable was the cruise cable, but since the ef/el even that doesnt exist anymore.
Old 17-03-2006, 10:09 PM   #5
JC
JC's Avatar
The cable should be tight - replace it with a new one.
Ford Performance Club ACT
Old 17-03-2006, 10:20 PM   #6
Racecraft
they call me Tibbo
Racecraft's Avatar
when you mean slack? Do you mean when you press the accelerator pedal the butterfly inside the throttle body doesn't respond or are you talking about how loose the black section of the cable is over the rocker cover? It has to have a certain amount of travel in the cable to allow for engine movement..
Old 18-03-2006, 12:20 AM   #7
GK
Walking with God
GK's Avatar
How hard is it to replace? How long will it take, and what's the cost? Actually I should do a search on the parts thingy!
I've never replaced a cable for a car before, plenty of motorbikes over the years though.
GK
Old 18-03-2006, 12:36 AM   #8
GK
Walking with God
GK's Avatar
The actual throttle cable is what I'm referring to. It has quite an amount of slack, so much that I can put my finger under it and lift without the engine even noticing.
I guess it must be stretched out to the max! The car has done 140,000 km's.
GK
Old 18-03-2006, 12:59 AM   #9
Racecraft
they call me Tibbo
Racecraft's Avatar
GK
3*13mm iirc nuts at the pedal .. You'll need a deep socket though.. Unclip it from the throttle body, undo the bracket on the rocker cover.. Then remove the little cir-clip thing from the c bracket and take the bracket off the rubber grommit.. Then pull it thru the car.. Re-install the newie in reservse order
Old 18-03-2006, 01:37 PM   #10
mattsAU1
mattsAU1's Avatar
my throttle cable on my AU1 is also slack and i asked my mechanic should it be tightened and all he did was get me to put my foot flat on the accelerator and he was standing at the front of the car with the bonnet up and felt to see if the throttle was in the fully open position with my foot flat. obviously the car shouldn't be running whilst doing this but if ur foot is flat and the throttle is completely open he said it is fine, only need to be adjusted if the throttle doesn't open completely when ur foot is to the floor
mattsAU1 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2006, 05:47 PM   #11
GK
Walking with God
GK's Avatar
I replaced it this afternoon. Took a while working out how to do it all, but now it's installed, the car has much crisper throttle response. I noticed it straight away!
GK
