Old 17-03-2006, 06:32 PM   #1
jedaarr
jedaarr's Avatar
Location: Nowra (Southcoast) N.S.W. Beutiful beaches no smog & plenty of grog & yes that is my dog.
Default Rear sway bar chassis mount breaking
I have owned a few ea fords, my Ist one the
under carriage sway bar mount support broke
away on the left side rear, it ripped completley
away from the support & left my rear left side
hanging loose banging around i only noticed as
i heard this thud clang from time to time & had
a look to see what the ^^^ was going on.
I pulled the gas tank out & my mate welded
the support back in after a lot of ^^around.
Well now my latest ea has broken away on
the right side & banging around it must be a
design fault i have not bothered to call a
welding place for a qouate & want to ask you
guys if u have had the same problem & will they
need to remove tank or can they weld it with out
removal as i no longer have a friend to weld the
^^^thing up & wonder what u were quoated. :
HOME BREW BEER SWINDLING PROFFESIONAL P-HEAD.
TO MANY YEARS IN THE MAKING : :1syellow1
jedaarr is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2006, 08:34 PM   #2
NZ
NZ's Avatar
I've never ever heard of sway bar mounts breaking away from the body. on any e-series, or au for that matter. I have heard of the front mounts stripping the bolts out when using larger sway bars but thats it.
EF Falcon Sedan 5.0 auto with IRS
"the man that crashs AFF"
Old 17-03-2006, 10:52 PM   #3
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
One of my mates mother's had this happen to their EA a while ago, I think tere's been a couple of other instances of it happening on the forums too.
If they have to remove the tank to weld, it's not hard to do, remove the fuel pump and undo the straps holding the tank in.
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2006, 01:06 PM   #4
niko
likes falcon's
niko's Avatar
how bloody hard do you drive man ?? lol
www.carhubsales.com.au
Old 20-03-2006, 09:37 AM   #5
EA2BA
PM me if you want
EA2BA's Avatar
Happened on my TC Cortina about 12 years ago cost around $600 for the upper mount to be fixed.
Old 20-03-2006, 03:58 PM   #6
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
This is the first time ive heard of this happening, i have had a clunk in my left rear for a while, i might go check.
:P
Kerry
Tickford wings are for Tickford cars!
"Experimental Racer" #6
1994 Gunmetal XG XR6 1997-1999
[B][COLOR=Red] 1994 Le Mans Red ED
2008 MA XR5 Mondeo
2015 VOLVO V60 T6 R-DESIGN-POLESTAR Enhanced
TIKFD6 is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2006, 08:43 PM   #7
EA_Bender
Hmmm Gold!!!
EA_Bender's Avatar
Hmmm this is a little worrying... I just upgraded my swaybars and im getting a clunking in the read left too... I'll definately have to check this out...
1990 EA Series 2 Fairmont, Low Springs and shocks, 17 x 7 Advanti Flash Mags running on Falken rubber :, EL XR8 Sway Bars, NGK Iridium Plugs, New Trip Comp, Pacemaker 4480, 2.5 system 4L ED engine with surecam
Now Sporting - OED666's 202+ RWHP engine!! :dj: fully
EA_Bender is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2006, 09:21 AM   #8
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
Well i went and did some searching yesterday afternoon, i found my clunk.
It wasnt the swaybar, which is fine.
Mine was the rear left door, both adjusters where very loose.
Kerry
2008 MA XR5 Mondeo
Old 21-03-2006, 09:29 AM   #9
luke
Yeah I've got this mysterious clunk in the rear left too... Happens mainly on acceleration when hitting a bump with the rear left wheel... Might be time to have a look at it :
2003 BA XT Wagon, I6, 4sp Auto, Dual Fuel, Prins Autogassystemen VSI LPG
RIP:
EA S MPFI 5 speed sedan w/exhaust, LSD, tint, 225's, DBA Golds, EL twin thermos, dual fuel and fluffy dice ; Stolen, recovered and written off, 7th April 2007
luke is offline   Reply With Quote Multi-Quote with this Post
Old 21-03-2006, 07:10 PM   #10
TIKFD6
Number 5 is alive!
TIKFD6's Avatar
Luke, check your door.
Kerry
2008 MA XR5 Mondeo
