Old 19-03-2006, 02:53 PM   #1
ED Incarnate
Chief Skirt Inspector
ED Incarnate's Avatar
Default Central Locking Actuator Installion Problems =/
Hey guys,
I've got a 93 dec, ED and the actuator on the left front hand side passenger side decided to pack up the other day. picked a spare off the wrecker for $25.
new actuator functions fine, its exactly the same as the former actuator however when fitting it to the car i used bolts instead of rivets to attach it to ensure it aligns up correctly.
I've screwed it in and locked the car however when the actuator arm actually goes down it doesn't quite go the full extension and consquently goes back up the original unlock position, however if i unscrew the actuator and move it up (physically hold it) a few mm from the original drill holes it functions fine...
do i need to put on a new piece of sheet metal and rescrew the holes so it functions correctly, i mean its exactly the same how can it not physically get the required length so that it gets in the lock position? I am still using the older existing steel rod that attachs to the actuator as its exactly the same length as the one it came with
this is really frustrating any help would be greatly appreciated. thanks
ED Incarnate is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2006, 08:57 PM   #2
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
nah mate move the rod on the door handle up or down i had the same problem when i change to EL door handles ,and fixed the same problem by doing that
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
TURBO_GHIA is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2006, 11:43 PM   #3
ED Incarnate
hey monty i was looking at it today and the rod that attaches to the door locking mechanism (the one that the actuator pushes up and down) looks like it cant really go any lower, when i lock it, the actuator draws the rod down but it can't go down to the required length (needs like half a cm more lower) so that it locks into position. cause it goes down but not far enough it gets the ИИИИs and goes back up. i can't pull the rod down low enough so that when the actuator is locked its sitting flush.
its really weird cause the rod is exactly the same its just a new actuator in the same fitting.... :( any suggestions?
Old 20-03-2006, 11:48 PM   #4
TURBO_GHIA
hmmm boost
TURBO_GHIA's Avatar
well i only pulled mine out and sort of pushed it back in it prob moved 5 mm if that and it now works so i assumed thats what i was cause i didnt move or touch anything else
EL TURBO GHIA
GT3582R
WOLF3D
TUNED BY JEM
