01-04-2006, 09:47 AM | #1 | ||
Hmmmmm
hey guys,
just got a set of ford territtoryt mags for the EA yesterday....$300 with new rubber! They look sweet as, but ive got a lil problem, The two backs go on fine, but when i was putting on the fronts they go on but they hit the suspension arms the sit in the wheel arch.....a mate suggested using spacers but that idea doesnt really appeal to me. The wheels are 17's, but they dont have low profiles so i was thinking is should try and put some on to c if it helps. I was hoping that there might be a cheaper option tho? |
01-04-2006, 10:25 AM | #2 | ||
Rocket Fuel Anyone?
Interesting, got any pics ?
01-04-2006, 11:48 AM | #3 | ||
you will need 30mm adapters, im pretty sure there the same offset as AU/BA rims.
01-04-2006, 12:50 PM | #4 | ||
how do he rear's fit the pre AU offset?
i was led believe that thy wouldent fit EA-EL's because of the offset i was thinking of getting two for the rear and paint them gloss black;D |
01-04-2006, 12:53 PM | #5 | ||
There the same offset as AU/BA so you will need spacers or hub adaptors!
Also im fairly sure the back ones will fit but not the fronts, as i have seen e-series running AU stockies... |
01-04-2006, 12:57 PM | #6 | ||
Rears will fit but sit in an inch.
You need bolt on adaptors, 4x of them, not just 2
01-04-2006, 04:42 PM | #7 | ||
Hmmmmm
yeah got it sorted, put 12/16 spacers on the front with a set of low proflies and it all bolts up nicely! ill get pics up soon
EDIT: heres a pic Last edited by JUZXR8; 01-04-2006 at 05:10 PM. |
02-04-2006, 12:51 AM | #8 | ||
Rocket Fuel Anyone?
Looks pretty good actually, very original.
02-04-2006, 08:07 AM | #9 | ||
Hmmmmm
yeah for the money i paid i really impressed, im goin hunting for centre caps now
02-04-2006, 08:38 AM | #10 | |||
windsor user
what you're doing with using regular shiitty spacers, is putting alll the weright of the rim and car on the wheel studs, not on the center spiggot of the hub.. this will cause your wheel studs to break......and you can tell what hte end result of that will be.... |
