Old 04-04-2006, 09:56 PM   #1
syktlr
stktlr
syktlr's Avatar
Default New Motor In Buttttttt?
Motors In And It Sounded Good But When I Drove It It Was Like There Was A Lack Of Power And It Would Not Rev Out And Stay In Gear.then Another Time It Took Of From The Lights Okay And Went Up The Hill At The Speed Limit Fine And Changed Gears Fine.pulled Up At The Next Set Of Lights And It Struggled To Take Of Like It Didnt Wont To Accelerate And Took Forever To Change Gears.any Ideas? When In N It Revs Fine.would This Have Anything To Do With The Torque Converter As We Did Change It Even Though It Came Of A Working Car.
syktlr is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2006, 10:02 PM   #2
BABOSS
BABOSS's Avatar
What car is it mate?
BABOSS is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2006, 10:04 PM   #3
LUXO_8
windsor user
from that description, top up the trans fluid.....
Old 04-04-2006, 10:11 PM   #4
syktlr
stktlr
syktlr's Avatar
Default Its An Ea With Ef Motor
Ea With Ef Motor In It I Put New Trans Fluid In It.how Much Should It Take?
Old 04-04-2006, 10:15 PM   #5
Damo
why do you type with capitols at the start of every word ? is that time consuming ?
Old 04-04-2006, 11:18 PM   #6
oneredED
need more boost
oneredED's Avatar
I was wondering that, and also the fact that those that would actually require a capitol, for example first letter of a sentence dont have capitols...
'94 ED Falcon GLi
Suspended by: kings, koni, pedders
Rolls on: 17" AJR Director's
Stops due to: bendix, DBA
Shifter connected to: T5 manual
Power from: ???
Interior: velour and woodgrain
Cost: stuff all :P
oneredED is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2006, 11:21 PM   #7
vegabass
BASS ON BOARD!
vegabass's Avatar
4 litres. are you sure its not in limp home mode?
Nothing interesting to put here.
vegabass is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2006, 11:34 PM   #8
2kool4u
Location: I live in my own little world, but it's alright, the people know me here
what Is Limp Home Mode??
Man who walks through plane door sideways is going to Bangkok.
2kool4u is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2006, 11:57 PM   #9
vegabass
BASS ON BOARD!
vegabass's Avatar
Where the auto or other associated elements detect a fault or a problem with the system (usually electrical) and it automatically locks the box in 3rd gear.
So from a standstill it will start in 3rd and it depends on the fault or problem if it will shift into 4th or not.
Usually s4 solenoid is a common problem in the BTR box... *
*its 11:45 and I’m dribbling $hit on the forum, information subject to being wrong.
Old 05-04-2006, 12:06 AM   #10
TwistedEL
TwistedEL's Avatar
This thread is wayyyy to hard to read
Old 05-04-2006, 07:25 PM   #11
syktlr
stktlr
syktlr's Avatar
mines 3spd.i filled up trans fluid and it is still doing it.i did notice on the cfi that there was 2 plugs coming of it they are on the firewall side at the bottom.on my old 3.9 it only had 1 thus my loom only has 1 would this affect my car? where is this s4 solenoid?
Old 05-04-2006, 07:29 PM   #12
Poetic Justice
NOT A TOYOTA :/
Poetic Justice's Avatar
In answer to your question, whenever someone types with caps lock on the forum automaticaly changes the rest of the word to lower case to stop the "yelling" impression...
06 LandbargeCruiser Sahara
Managed to remain in the v8 fraternity
Poetic Justice is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2006, 08:17 PM   #13
TURBOTAXI
Turbo Falcon Fiend
TURBOTAXI's Avatar
See if your sensor on the firewall is connected (MAF or MAP)
Just a few.
TURBOTAXI is offline   Reply With Quote Multi-Quote with this Post
Old 05-04-2006, 08:23 PM   #14
syktlr
stktlr
syktlr's Avatar
is that the black part on the right side of the wall when looking at it
Old 06-04-2006, 10:34 PM   #15
Walkinshaw
Two > One
Walkinshaw's Avatar
Yes that is the MAP sensor.
Being an EF motor im guessing you have used the EF intake manafold, or have you put the EA intake manafold onto the EF motor.
If you are using the EF manafold and have converted to MPFI, you need to
(1) change your fuel pump to an MPFI item
(2) rig up a kickdown cable for the 3speed trans.
If you are still using the CFI manafold, makesure the kickdown is adjusted properly
