Old 19-08-2006, 06:40 AM   #1
greyute
greyute's Avatar
Default compression test time
I'm am going to be getting a compression test done on my car as it is using a bit of oil.
Its an AU2 XR6 VCT
Does anybody know what numbers i should be looking for?
Hopefully its ok.
: FALCON BEAUTIFUL :
[COLOR=Gray]
greyute is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2006, 07:55 AM   #2
bodes-sh
if you have a service book, like gregory's, etc then it should tell you in that. there are a lot of things that can affect the result, like how many km the car has done, how often it has been serviced, etc
Old 19-08-2006, 09:20 AM   #3
greyute
greyute's Avatar
Don't have a Gregory's, but was hoping someone might have.
The car has done 135K and has been serviced regularly but has had a trailer on it almost all of the time so it has worked.
[COLOR=Gray]
Old 19-08-2006, 09:43 AM   #4
CATFORD
SCALDED CAT
CATFORD's Avatar
Hi Mate.... the numbers you should be looking for are....
100-650 kPa ( all cylinders need to be within 100 kPa of each other )
(must crank engine over several times before you achieve the correct numbers)
If compression is low...pour a table spoon of oil into the sparkplug holes....if compression improve vastly....then it is your rings....if it doesnt improve with oil your looking at a broken ring or valves ethier burnt or valve seats....if two cylinders are just the problem it could indicate a simple head gasket problem.
Anyway hope this helps you out....and good luck!!! :
"THE CAT IS BACK"
CATFORD is offline   Reply With Quote Multi-Quote with this Post
Old 19-08-2006, 03:33 PM   #5
bodes-sh
the other thing that can cause oil usage without affecting compression is valve stem seals...of course if it is only these they are a lot easier to replace than rings or a head gasket
Old 19-08-2006, 03:33 PM   #6
greyute
greyute's Avatar
Cheers lads hoping on good results. Fingers crossed...
[COLOR=Gray]
Old 20-08-2006, 01:03 PM   #7
Baboon_AU
Baboon_AU's Avatar
when u do your valve stem seals your head has to come off and thus u have to replace your head gasket.. i would say head gasket is a lot easier than valve stems seals mate
01 AUII XLS Regency Red Ute 4.0L Egas Auto
Mods -transcooler, tickford intake, K&N pod filter, Pacemakers, 2.5 inch exhaust, Crow Cam,
1981 XD Fairmont 351 - 351 Cleveland, ARP bolts, flat top pistons, Stage 3 Dynotec cam, ported 2V heads with 4V valves, Roller Rockers, Weiand manifold, Mighty Demon, 1/2" fuel lines with blue Holley fuel pump, Crane hi-6 ignition, B&M megashifter, C4, hi-stall, shift kit, 3.77 Ford 9" LSD.
Thanks to: EvilChief and SJW Performance
Baboon_AU is offline   Reply With Quote Multi-Quote with this Post
