Old 20-08-2006, 03:36 AM   #1
HoT-AU
06 SS Thunder Ute
Default AU Door Trim
Ey guys,
I jumped on aufalcon.com for this and i found the workshop article but it didnt actually help me. With the AU door trim i removed all the screws hidden behind the caps but it seems to be anchored at the door handle. I look around the door handle and could find where the problem was. Im assuming a hidden screw?
Any help would be muchly appreciated. Its an AU1 Fairmont Ghia. Thanks.
Ford..Holden.. Not fussed lol
HoT-AU is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2006, 03:40 AM   #2
blackers10
blackers10's Avatar
there is the bolts on the bracket in there somewhere from memory.. it doesnt look like its holding the trim on but it is.
if its the front door check under the flip up pockets..(my lane has flip up front armrests)
if you can see a bolt/screw it needs to be undone..from my previous experience.
Old 20-08-2006, 06:06 AM   #3
Racecraft
they call me Tibbo
Racecraft's Avatar
there is a 10mm bolt under the door handle cup... there is also a screw under the power window switches
Old 20-08-2006, 10:04 AM   #4
AUIII
AUIII's Avatar
I removed mine following JC’s excellent instructions in this thread.
http://www.fordforums.com.au/showthr...g+AU+door+trim
Current Ride 2012 Mitsubishi Triton Dual Cab ute :
AUIII is offline   Reply With Quote Multi-Quote with this Post
Old 20-08-2006, 10:48 AM   #5
HoT-AU
06 SS Thunder Ute
hmmm okay. Ill go have another look and if i get stuck again ill get back to u all. Thanks guys.
Old 20-08-2006, 04:15 PM   #6
HoT-AU
06 SS Thunder Ute
EVENTUALLY i got it off. i didnt have the right tools to start with, but when i got a sprocket set it was a treat. Thanks for the help guys! much apprecitated!
