02-09-2006, 01:32 PM | #1 | ||
EF XR6 5spd
can any one tell me how to remove the rear bar of an ef gli sedan.
I had a look under it and only saw 1 bolt in the top left and right corners is that all there is to it |
02-09-2006, 02:18 PM | #2 | ||
OPT 20
Take off the bumper end shields (inside rear guards).
Remove retaining screws at the top of bumper from inside the guards. Remove the attaching bolts in the boot. Some models have a plate attached to the spare wheel well which is screwed or riveted to underside of the bumper - remove screws or drill out rivets. Slide bumper rearward and disconnect the number plate lamp wiring - remove bumper completely.
'94 EF GLI Dash Mat Color-coded Ashtray Polished Wheel Nuts |
02-09-2006, 03:45 PM | #3 | ||
EF XR6 5spd
thanks i did all that but i missed two of the bolts higher up on the mounting brackets
