Old 12-09-2006, 06:46 PM   #1
UltraLowEd
Default Alot of work needed for this
Hey all i have an ed fairmont and im wanting to put an el handbrake in and im wantin to know what i have to do to make it fit.
UltraLowEd is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2006, 06:52 PM   #2
TUF_302
The Vengeful One
TUF_302's Avatar
Umm why??
TUF_302 is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2006, 06:55 PM   #3
UltraLowEd
i dont like where the handbrake is its annoyin
Old 12-09-2006, 06:59 PM   #4
kyro_02
V8 wannaabeee
kyro_02's Avatar
i would like to know.. soo has it been done before and is it be hard to do ?
kyro_02 is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2006, 07:05 PM   #5
UltraLowEd
ive been told it can be done but i dont know if this is true, u have to put an el center console in and put an el diff in and cut a whole in the chassis, not sure if thats rite or not
Old 12-09-2006, 07:37 PM   #6
ROOSTA
DFDFDF
ROOSTA's Avatar
Or put in a fully sick DRIFT SPEC hydraulic handbrake..
I wouldn't mind one.. LOL..
Cheers,
Nik
ROOSTA is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2006, 07:38 PM   #7
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
its a PARK brake. for PARKING.
BA MK2 XR6T
ON_DUBS is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2006, 07:40 PM   #8
Rollin
Rollin's Avatar
Ok, new question.
"How do I fit a decent handbrake that I can use for drifting?"
Rollin is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2006, 07:41 PM   #9
LUXO_8
windsor user
hehe...
Old 12-09-2006, 07:41 PM   #10
UltraLowEd
well dah!!
Old 12-09-2006, 07:44 PM   #11
Tiga_EL
Tiga_EL's Avatar
Umm. itd prolly be a bit more cheaper and maybe Roadworthy to buy an EF/L
Tiga_EL is offline   Reply With Quote Multi-Quote with this Post
Old 12-09-2006, 07:45 PM   #12
UltraLowEd
Thats probly true
Old 12-09-2006, 07:47 PM   #13
ROOSTA
DFDFDF
ROOSTA's Avatar
LOL.. Probably.. Engineering certificate required... So already $700.. Plus diff and handbrake setup $500 - $1000.. Then manufacturing all of it into car..
Without labour straight up i guess at $2000...
Cheers,
Nik
Old 12-09-2006, 07:49 PM   #14
UltraLowEd
Yeah maybe i should just leave it
Old 12-09-2006, 07:56 PM   #15
ROOSTA
DFDFDF
ROOSTA's Avatar
I currently looking at converting to hydraulic handbrake which operates only rear.. Not sure how to go bout it though...
Cheers,
Nik
Old 12-09-2006, 08:44 PM   #16
ON_DUBS
[ON DUBS]
ON_DUBS's Avatar
Ok, new question.
hahah nice one :
BA MK2 XR6T
Old 12-09-2006, 09:32 PM   #17
Rollin
Rollin's Avatar
The EF/L handbrake setup isnt very good for drifting due to the drum-in-disc arrangement on the diff...its easy to break and/or wear down the handbrake shoes and they become useless very quickly.
EA/D setup has much better potential, as it uses the rear calipers themselves, so it is self adjusting and probably has a higher surface area and better mechanical advantage than the EF/L setup - EA/D is actually a 'handbrake' and EF/L more of a "park brake" if you take into account the design and operation of each setup.
Old 12-09-2006, 09:33 PM   #18
Rollin
Rollin's Avatar
Old 12-09-2006, 09:41 PM   #19
kyro_02
V8 wannaabeee
kyro_02's Avatar
yes ford should of thought earlier about people wanting to drift :(
Old 12-09-2006, 10:37 PM   #20
efgiar
rofl copter
efgiar's Avatar
sif handbrake, the power that a falcon i6 puts out is enough to get it sideways by planting it! haha
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2006, 09:17 AM   #21
TUFED6
TUFED6's Avatar
Could you use an EF/EL lever, and just shorten an EA-ED cable? I haven't seen the guts of how an EF/EL setup works.
Welding the brackets etc. onto an EA-ED floor seems simple enough, and I'm guessing you could use a combination of EF-EL seat rails and whatever else to make it fit...?
TUFED6 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2006, 11:03 AM   #22
Aaron_EF8
Oops, I slipped....
Aaron_EF8's Avatar
Hydraulic handbrakes are under $100 at most race parts shops, and will last a lot longer than any steel cable will. Drifting with a handbrake is soft anyway, just go faster :P
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust
1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust
"Just because you don't understand something, does not make it wrong"
Aaron_EF8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2006, 11:29 AM   #23
niko
likes falcon's
niko's Avatar
it just pulls the cable in a semi cirle
www.carhubsales.com.au
Old 13-09-2006, 11:41 AM   #24
BlackLS
Go to pick and payless spares and compare the 2 cars handbrake mechanisms side by side.
Old 13-09-2006, 12:06 PM   #25
Psycho Chicken
Psycho Chicken's Avatar
Just put the whole interior in yagz.
Old 13-09-2006, 12:08 PM   #26
Walkinshaw
Two > One
Walkinshaw's Avatar
Respect-a
Old 13-09-2006, 04:33 PM   #27
dansedgli
dansedgli's Avatar
Da Fish isnt yagz. He came to my house to check out my bonnet on the weekend. Definately not yagz.
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2006, 06:24 PM   #28
XPfalcon170
XPfalcon170's Avatar
if ya going to go to all that trouble for drifting, then put in the hydraulic handbrake. All the rally guys i know use them in their cars cause there better than the cable
XPfalcon170 is offline   Reply With Quote Multi-Quote with this Post
Old 13-09-2006, 06:25 PM   #29
dansedgli
dansedgli's Avatar
How would you run the hydraulic handbrake?
How would the lines go on an E series?
Old 13-09-2006, 06:30 PM   #30
Kenaz
Kenaz's Avatar
Good thing you said something. There was probably a mod ready to ban his *** :
02 BA XR6 T U R B O
Venom Red, Auto 13.97 @ 101mph
Originally Posted by Wheels Nov 02
It's suave, more subtle, and yet no less stirring. In fact, the boosted Ford is more polished than any big sedan Australia has ever produced. It's just so damn good, it makes the SS feel crude... Ignore the WRX. Forget the E49. Falcon XR6 Turbo is king.
Kenaz is offline   Reply With Quote Multi-Quote with this Post
