Old 06-09-2007, 04:57 PM   #1
mark180227
mark180227's Avatar
Default what would cause this?
found this on the car today. i dont know how it happened or when. but i do remeber the other night, something hitting the car while driving, i nearly shat myself.
pretty p/o at the moment, i had paid for everything i needed to and it was trouble free, but then this comes along.
how much would i be looking at for a new bonnet? or a repair?
mark180227 is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 05:02 PM   #2
poolkeeper
Its Resonating!
poolkeeper's Avatar
Good excuse to get a carbon fibre bonnet now
Looks weird, like someone drilled a hole in your bonnet or bullet?? lol
poolkeeper is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 05:50 PM   #3
ayeyew
Teh Baest
ayeyew's Avatar
Were u driving near an overpass?
Kids these days seem to enjoy chucking stuff off them
1999 Liquid Silver AU
Show: XR6 Kit, Low, RDA Slotted's F&B, Fully Tabouli Sound System, Altezza Tailights (Good ones!)
Go: K&N Pod w/ 3" intake, XR6T Snorkel, Pacie Comp 4480's, 2.5" Cat Back, CMS Stg2 Cam, Custom Tune, Tranny Cooler
Coming..CMS Stg2A Cam, 68mm TB
Later.. 4.5L w/ BOOOOOOOOOOST or XR6T or AUIII XR8 220
Currently:
151kW (165 on other dynos )
ayeyew is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 06:03 PM   #4
XR6Stu
It takes a fair bit of force to punhc a hole in a bonnet like that... whatever has hit it has hit it bloody hard at high velocity. Lucky it hit the bonnet and didnt hit you after going thru your windscreen. My guess is a rock (doubt it though, unless thrown off an overpass, still doubt it, ) or as unlikely as it sounds a bullet is the only thing i can think of that would do that sort of damage to a bonnet.
XR6Stu is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 06:12 PM   #5
superroo
You can't stop the signal
superroo's Avatar
it looks like it's come through the bonnet (engine bay to outside word)
Old 06-09-2007, 06:13 PM   #6
DoreSlamR
Fiat POWAAH!
DoreSlamR's Avatar
It looks like maybe something has come from inside the engine bay?? Like something got flicked off the fan belt?
DoreSlamR is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 06:53 PM   #7
FGII-XR6
FGII-XR6's Avatar
mark is it an innie or an outie
Old 06-09-2007, 06:55 PM   #8
Umineko
Karasu
Umineko's Avatar
Looks like damage from the tray of a 4X4 ute backing into you, steel frames under dropside utes could easily punch a hole in a bonnet without too much effort. would explain the other scratches as well
Umineko is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 07:03 PM   #9
private9
www.TUFFCARPARTS.com
private9's Avatar
You've got my vote!
Old 06-09-2007, 07:11 PM   #10
mark180227
mark180227's Avatar
lol, definately something has punched it from the outside. the metal is pushed inwards towards the motor.
no over passes, but after finding the hole i considered my self lucky what ever hit me didnt come through the windscreen. i cant see a rock doing that much damage, but who knows.
so where do i go from here. new bonnet most likely option. how much am i looking at?
Old 06-09-2007, 07:17 PM   #11
FGII-XR6
FGII-XR6's Avatar
if you were doing 110 under a bridge and some idiot rocked you that may happen . you can get new bonnets (repro) for 220 to 240 or check fibre sports ( forum sponsor )out for fiberglass bonnets with the bulge might be just the excuse you need
Old 06-09-2007, 07:35 PM   #12
Pinkbits
Pinkbits's Avatar
Reread the first post, WHILST driving.
My money is on something falling from either a passing car or from one you may have been behind, possibly a piece of metal.
Pinkbits is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2007, 07:41 PM   #13
ayeyew
Teh Baest
ayeyew's Avatar
Depending on how high the overpass is, consider a medium-large rock (5 kg or so), being thrown off the overpass and it hit your bonnet on an edge.
Rocks will be accelerating at around 10m/s^2, so by the time it hit your car it would be travelling at around 70+km/h, if all that energy was concentrated into a single point (or apex) on the rock and distributed over a limited time frame, the impulse of that would be significant enough to cause quite a bit of damage!
Im sure you have seen rocks causing massive damage to windscreens and stuff in the news recently, granted that windscreens are much less resistant to such impacts, but such energy transfers could result in a significant amount of damage. Think about you wielding an axe onto a car bonnet, or a pitchfork.
That is similar to what a rock launched from a 30meter platform could do (I have no idea how high overpasses are
Maybe me and my physics should stfu, i am under the influence of Jim Beam Long Blacks (2.1 standard drinks per bottle & on special at liquourland 17.99 for 4) :
Currently:
Old 06-09-2007, 07:45 PM   #14
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
Whatever hit you was small, solid and was moving at a high rate of knots.
I had a 50cm hunk of 2x3 wood hit my bumper, then the bonet then bounce over the car whild driving towards the 'gong many eons ago.
It fell off the tray of a tabletop truck. He pulled over and it all got sorted out.
But even that just chipped some paint on first contact with bumper, then caused a slight dent and a tiny chip on the bonet.
Have you had your car serviced recently? I had a similar dent (but no puncture) in the roof once when the car went up on a hoist in a workshop.
Old 06-09-2007, 07:52 PM   #15
ayeyew
Teh Baest
ayeyew's Avatar
^^ The actual object itself may not have been small, just the bit which made contact with the bonnet was small
BTW, Go for one of those Boss bonnets off ebay
Like $650 i think i saw them for, they look HOT
Currently:
Old 06-09-2007, 08:13 PM   #16
galaxy xr8
Giddy up.
galaxy xr8's Avatar
How on earth did it hit there without hitting the bonnet protector 1st????????, it is to close to the protector to have come from another vehicle infront in my opinion.
Old 06-09-2007, 08:28 PM   #17
Stav
Smile
Stav's Avatar
Thats hard to pick.Whatever it was hit with alot of force.Those bonnets don't get holes that easily. Lucky you weren't hurt.
Old 07-09-2007, 11:16 AM   #18
xr8 007
xr8 007's Avatar
my vote would be a kid with a sling shot!!!! because even if it was a rock that was thrown it would not have gone in like it did. It would have needed Some serious force.
Build Thread: BA XR8 with all the goodies.
fordforums.com.au/showthread.php?t=11247663
xr8 007 is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2007, 11:25 AM   #19
FGII-XR6
FGII-XR6's Avatar
the serious force is a car doing freeway speed . when you think about it hitting anything at 100+ Ks will do a lot of damage and if it's small and pointy it may make a hole
Old 07-09-2007, 12:42 PM   #20
xr8 007
xr8 007's Avatar
but look at the size of it! it would have needed extra force for something that small, otherwise we would all have holes in our cars from small rocks and stuff
Old 07-09-2007, 01:59 PM   #21
KITBAG
KITBAG's Avatar
I Recon they were made by 4X4 ute backing or truck backing in to it.... :
As for type off 4x4 or truck maybe onr of the follwing................
KITBAG is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2007, 02:03 PM   #22
xrfranjo
whats that noise
maybe it was a bullet coming from iraq?
xrfranjo is offline   Reply With Quote Multi-Quote with this Post
Old 07-09-2007, 06:52 PM   #23
XR6Stu
why wont anyone listen to the panel beater? AU bonnet due to the massive open flat panel, have alot of stretch in them. Rather than just push a dent in it, whatever it was has hit the bonnet VERY VERY hard, and wouldnt be any bigger than the hole it made. Admittedly, probably not a bullet as I tongue in cheek suggested, but something of similar size, and probably a bit heavier. Although I gotta admit the other scratches have me stuffed.
Old 07-09-2007, 07:41 PM   #24
clontarf_x
Something large and metallic has definately hit that dude...
clontarf_x is offline   Reply With Quote Multi-Quote with this Post
Old 08-09-2007, 08:55 PM   #25
Mechan1k
Mechan1k's Avatar
If you read the post though ... it was done while driving.
I am sure at highway speed hitting the back of the stationary 4WD ute would have killed him and totalled his car.
My view ... i am stumped on this one ... seeing as there was no overpass in the vicinity ... it rules out the goose throwing rocks ... although there have been issues with idiots throwing rocks from the sides of highways on embankments from bushes though.
Could have been debris from another vehicle ... if there was something in the vicinity yet again.
I was lucky myself one time ... a chunk of coal came off the back of a trailer and bounced right in front of me and clobbered the top of my left driving light and launched over the roof of the ute ... in line with me as it narrowly missed the windscreen ... I shat myself.
I checked the driving light later ... not a mark on it ... thank god for Lightforce driving lights ... at least the plastic fantastics are strong ... they have passed the 12 gauge shotgun test from 8 feet away in initial testing. I can now prove that a massive chunk of coal at 115km/h doesn't leave a mark on them either.
Old 09-09-2007, 11:40 AM   #26
No Judge
That's Numberwang!!!
No Judge's Avatar
[QUOTE=mark180227] i dont know how it happened or when.
Just a maybe, but are we sure the scratches and hole happened at the same time???....
Scratches from 4x4, & hole from kid with VERY strong throwing arm...
www.aufalcon.com.au/only1
FAIRMONT GHIA: SO GOOD, THEY NAMED THEY NEW FALCON AFTER 'EM
Originally Posted by xr6 ausome
Nah the roads to high, your car can never be to low lol
No Judge is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 01:53 PM   #27
Jokular
Jokular's Avatar
Was there a truck in front of you? sometimes they spit up pieces if their brakes like the guy that was killed recently.
Jokular is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 02:14 PM   #28
The Monty
Just slidin'
The Monty's Avatar
I cant see how it could be a rock. I hit rocks all the time, they barely even dent the AU, and sometimes dont even take chips out, at 100k/ph. I hit a fruit bat at 100, and it just took a little paint off. Id vote for a bullet as far stretched as it may be, or a piece of a truck brake, but the force of it hitting the car, would be enough to make someone pull over, youd know it had done damage.
This is quite a dilly of a pickle.
MD Mondeo - For the family
NP Pajero - For the adventure
Old 09-09-2007, 02:54 PM   #29
tankclare
BURN RUBBER NOT OIL
tankclare's Avatar
something has fallen off a truck or another passing vehicle.
I was once driving past the mines near singleton / jerrys plains and got hit with a piece of coal from a passing truck..scared me at the time haha
[TUFF4L] EF Fairmont Ghia build thread - http://www.fordforums.com.au/showthread.php?t=11381891&highlight=tuff4l
[SMOKES] FG XR6 build thread - http://www.fordforums.com.au/showthread.php?p=4795218#post4795218
tankclare is offline   Reply With Quote Multi-Quote with this Post
Old 09-09-2007, 04:08 PM   #30
onfire
onfire's Avatar
Like others have said, can you confirm both the dent/whole and the scratches happened at the same time.
The scratches, easily could have been a rock.. but how do you know, someone didnt take a swing at your car with something.
onfire is offline   Reply With Quote Multi-Quote with this Post
