08-09-2007, 11:50 AM | #1 | ||
are they the same door for each car???
im trying to gety hold of a passenger door for an au ute, can i use an au sedans passenger door?? |
08-09-2007, 12:53 PM | #2 | ||
the ute is an au xr8 if that makes a difference...
08-09-2007, 02:21 PM | #3 | |||
08-09-2007, 02:54 PM | #4 | ||
www.TUFFCARPARTS.com
Yep, all pretty much the same!
http://i1233.photobucket.com/albums/...psc203b7b1.jpg |
09-09-2007, 07:13 AM | #5 | |||
Blown 5L coming
ivbe done heaps of research on this and have found the following.......
front doors are the same throughout wagon and fairlane rear doors are the same door cards are the same troughout.....ie long wheel base rear door cards will fit sedan rear doors so to answer your question, yes, you can get AU sedan/wagon front door to fit the ute, everything will swap right over if you have power windows and the door you buy has wind up.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
09-09-2007, 10:12 AM | #6 | |||
_Oo===oO_
The fronts would have to be the same or else it would've cost Ford a packet to make the AU.
09-09-2007, 12:41 PM | #7 | ||
Commercial Sponsor
series 1 & early series 2 doors are the same
late series 2 & series 3 doors are the same. you can pick this by the bailey channel rubbers. the early ones have a 1 piece rubber and the later ones a 3 piece rubber. there are extra provisions on the late doors for the rubbers to clip on. If you try and use the 1 piece rubber on a late door it wont sit correctly |
