My air bag light flashes on and off and then stays on when i start the car. I have checked the fuse and its ok.. any ideas?
Thanks |
Oops, I slipped....
The airbag light flashes out the error codes. Have a look at the following link, and go from there.
http://www.fordmods.com/forums/documents.php?doc=3
1995 EF Fairmont 5.0 Heritage Green - BTR with TCI 2500 stall - Ported E7's - Pacemaker Tri-Y's - 3" Mandrel-bent Lukey Exhaust 1984 XE S-Pack 250 Sno White - LPG - Single Rail - 2.5" Exhaust "Just because you don't understand something, does not make it wrong" |
XR6er
i had the same thing with mine - there is a air bag clear code on the computer connecter in the fuse box that you have to earth out to clear the light from the dash...but i can't remember which one it is...it's in the big service manual for ef/els though.
Aspiring mr efxr
happened to mine after having the dash out to fix the heater core. had to take it to ford to be programed
EF Wagon Project: Standard = 99.6rwkw <!> 2.5" SuperCat cat back exhaust, Wade 1636 cam, K&N boxed pod (new dyno required Sony headunit, splits, 6.5"s and 2 x 12" with response precision amp = 135.5 dB Daily = Ae82 '85 corolla Fwd :togo: , 5 speed, 12" sub, 6x9's, green LED's the course i am studying: http://www.wodonga.tafe.edu.au/01_courses/course.jsp?id=AUR30905NANA |
