Old 06-11-2006, 10:33 PM   #1
efgiar
rofl copter
efgiar's Avatar
Default EBII starving for fuel
hey guys, some of you may have read the other thread i made about a cat convertor symptoms, but this is beond that unfortunantly, ill run thru quickly what has been done
fuel pump
fuel filter
partial fuel line
fuel reg
rotor button
dizzy cap
leads
plugs
coil
cat convertor
timing
now what my problem is that under load it will miss and backfire, we kno its a fuel issue not spark. if we clamp down the return line it will run like a DREAM, even does burnouts in the driveway! now ive tried alot of things, checked vacuum, checked the tree it lives on etc etc etc. i cant check fuel pressure because i dont have a gauge for it, the pump is whining after 10 minutes of use and u hit the tank and it stops whining, now i think personally the pump maybe nackered and not putting out what it should. if anyone could help me id be very greatfull as i have done more to this car then has crossed my mind. i am going to put another fuel pump in tomorow and hopfully that gets it going because my uncle (the owner of the car) is ready to fill it full of dirt and use it as a pot plant so any ideas AT ALL will help thanks
GQ patrol.
thats all
efgiar is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2006, 10:40 PM   #2
Walkinshaw
Two > One
Walkinshaw's Avatar
Pump sounds shot. Clamping the return line will only increase the fuel pressure in the rail.
Old 06-11-2006, 10:42 PM   #3
EBFalcs
Try the TFI module too
EBFalcs is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2006, 10:44 PM   #4
Perana
Perana's Avatar
Sounds like the fuel pump to me.
Perana is offline   Reply With Quote Multi-Quote with this Post
Old 06-11-2006, 10:47 PM   #5
efgiar
rofl copter
efgiar's Avatar
thats ANOTHER pump, was in there a day and he said it started whinning but before the whining it start with the missing/backfiring problem
GQ patrol.
thats all
Old 06-11-2006, 11:46 PM   #6
efgiar
rofl copter
efgiar's Avatar
yeah but would that be because the pump isnt putting out enough volume to keep the injectors happy?
GQ patrol.
thats all
Old 06-11-2006, 11:56 PM   #7
Mr_4.0
What Wheelspin?
Mr_4.0's Avatar
correct!
2016 FGX XR8 (KPM StreetFighter Kit 455rwkw)
2003 BA Xr6 Turbo (Atomic Long, DTM auto, Nizpro stage2 kit, eaton truetrac, E85, HeadsexTuned)
Mr_4.0 is offline   Reply With Quote Multi-Quote with this Post
