Old 12-11-2006, 05:33 PM   #1
matt6n
Default Steering Wheel Controls
A couple of days ago the volume and seek buttons on my steering wheel stopped working (the cruise control buttons may or may not work, i have never used it). I had a quick look through the book for what fuse it could be and if it said what to do but I couldnt find anything.
Anyone know why it stopped working and how to fix the problem?
matt6n is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 01:05 AM   #2
matt6n
Also, the horn isnt working....
Anyone??
Old 14-11-2006, 01:09 AM   #3
BeStRaFe
lpg = big boom!
BeStRaFe's Avatar
its an AU ... THERES YOUR PROBLEM!!!
check the wiring harness...
disconnect the battery and pull of the airbag
check the loom is still connected..
or check the loom wherver it comes out of the steering colum
BF Futura Dedicated E-GAS w/Ghia bling
Project: 86 ZL Fairlane, Red, Sunroof, 310,000KM
BeStRaFe is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 01:35 AM   #4
JC
JC's Avatar
It is more than likely the "clock spring", which has nothing to do with a clock, and is actually a long, wound-up ribbon cable, not a spring.
Ford Performance Club ACT
Old 14-11-2006, 10:29 AM   #5
sixty9
my money is on JC!
JC is always 100% spot on.
It is the clock spring. Consider yourself lucky that the horn didn't continously come on while driving or while turning. As this is common when the clockspring goes, as the ribbon cable ends up being teared apart and wires touching. My horn was continuosly on while driving thru peak hr traffic, everyone thought i was going nuts, till i lifted up the bonnet and pulled the horn relay. from experience the clock spring sells for about $40-50 from wreckers.
sixty9 is offline   Reply With Quote Multi-Quote with this Post
Old 14-11-2006, 10:39 AM   #6
sixty9
if you are going to do this yourself, as bestrafe stated, you will need to disconnect battery and pull off the airbag. You will need the torq bits to remove the torq security scew.
Then remove the steering wheel. You might need a steering wheel puller or some good strong hammer technique from behind the steeringwheel. take off the clockspring and wiring harness. Then re-install clockspring, making sure to recentre the clockspring.
Old 14-11-2006, 03:38 PM   #7
JC
JC's Avatar
Originally Posted by sixty9
my money is on JC!
Thanks for the vote of confidence, but I am not always 100% spot on. Actually, I thought I was wrong once, but I was mistaken.
Old 14-11-2006, 05:40 PM   #8
janek
Ripping it up
my money is on JC!
is that why my horn was almost always on! I thought it was just from over use at the world cup! :P
but it doesnt do it any more :lookedat:
janek is offline   Reply With Quote Multi-Quote with this Post
