Old 08-12-2006, 07:40 PM   #1
FS5
Default welding/ecu???
i have to weld up a small hole on my exhaust and was wanting to know if you have to unplug the ecu before weldin?
thanks jake
FS5 is offline   Reply With Quote Multi-Quote with this Post
Old 08-12-2006, 07:44 PM   #2
bodes-sh
just the battery, or i'm pretty sure most exhaust shops have a type of surge protector, the battery can blow up if you don't either disconnect it or put one of those on...the ecu doesn't usually have anything running in it when the car is off
Old 08-12-2006, 08:48 PM   #3
FS5
thanks mate
Old 08-12-2006, 11:22 PM   #4
TwistedEL
TwistedEL's Avatar
The ECU has constant voltage as does the BEM I personally would disconnect both of the above as well as the battery just to be safe
Old 09-12-2006, 07:15 AM   #5
StealthAu
once the battery is disconnected, the circuit to the ecu & bem is also. no need to unplug them.
Old 09-12-2006, 07:43 AM   #6
FPV329
Workin' for the BOSS
FPV329's Avatar
You should always disconnect the battery before any electric welding on the car. Arcing across the alternator can destroy it.
Ford Racing Alloy Blocked Custom Built 5.4L Harrop/Eaton Blown Boss BA XR
FPV329 is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2006, 02:10 PM   #7
congo3sr
Thumbs up
agreed,you should also make sure your return lead (earth clamp) is making good contact with the piece your welding,and as close as possible,this way the current wont be running everywhere thru the vehicle.
goodluck
congo3sr is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2006, 09:27 PM   #8
mik
mik's Avatar
in the ford manual it says disconnect negative battery lead.
