Old 24-01-2007, 08:27 PM   #1
Xplode0185
Xplode0185's Avatar
Default smokey ed
hey guys my brother has a ed falcon it has been running fine untill the other day when he toped it up with oil now ever since then every time you start it when its cold it smokes really heavy for bout 5 mins then just clears up does anybody have any ideas on what it might be?
thanx in advance
Xplode0185 is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 08:29 PM   #2
10secondET
one day
10secondET's Avatar
probly valve stem seals
XY GTHO MOCK
406 cleveland grout filled, pavtek alloy girdle
scat 4340 crank, scat h beam rods 2000 series bolts
CHI cnc 2v heads
comp 308r solid roller camshaft
torque power single plane manifold
950 quickfuel race carb
pro trans c10 with transbrake
5500 tce converter
3.89 diff gears
10secondET is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 08:32 PM   #3
Xplode0185
Xplode0185's Avatar
how mutch would they cost to fix?
Old 24-01-2007, 08:33 PM   #4
XR_Lightning
Riding The Lightning
XR_Lightning's Avatar
head needs to come off, the problem is defintely head/piston releated
ED XR6 - T5 - 1521a@112 - 3.9's - 170.2rwkw - POWERED BY METALLICA
XR_Lightning is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 08:41 PM   #5
10secondET
one day
10secondET's Avatar
you can do valve stem seal with head on you need to fill each cylinder(one at a time) with comprested air the get your self a head on valve spring compreser and spring off new seal spring on and so on cylinder by cylinder
XY GTHO MOCK
CHI cnc 2v heads
5500 tce converter
3.89 diff gears
Old 24-01-2007, 08:44 PM   #6
Xplode0185
Xplode0185's Avatar
we where wondering if he could have put to mutch oil in would that make it smoke?
Old 24-01-2007, 08:45 PM   #7
LUXO_8
windsor user
too much oil will make it smoke......
check the level on the dipstick thats what it is there for
Old 24-01-2007, 09:17 PM   #8
Christiaan
Tuned @ Pitlane Frankston
Christiaan's Avatar
Umm, check the oil level.
More than likely though, your brother has put a thinner oil than should have been put in there, and it's either;
a) getting through the rings and smoking that way
b) getting through the valve stem seals
If the oil level is ok, you can use a thick oil, such as 20w/50, 25w/60 or 25w/70. This will mask the problem until even a thick oil will get through and blow smoke.
Then it'll be time for a new engine/major engine repairs.
BA MKII XR6 Turbo, 6sp Manual - Vibe purple, Premium sound, Sports leather, BA XR8 wheels, Koni adjustable suspension, Nizpro v/springs, Walbro in-tank pump, Siemens 60lb injectors, Process West stage 1 intercooler, Mal Wood 11" Option 3 clutch, Tripod gauges, Custom Mainlube T56 gearbox oil, ETM turbo oil feed line, Typhoon intake, BMC Panel filter, Turbosmart BOV, Tuned by Pit Lane Performance - 300.4rwkw @ 12psi
Christiaan is offline   Reply With Quote Multi-Quote with this Post
Old 24-01-2007, 09:42 PM   #9
DJ1979
and then some
DJ1979's Avatar
could aso be pcv valve. My car used to smoke for about 30 seconds on a cold start - new pcv valve and have had no issues since.
$20 something from ford
DJ1979 is offline   Reply With Quote Multi-Quote with this Post
Old 25-01-2007, 10:16 AM   #10
EdFairmontGhia
ED_Ghia
EdFairmontGhia's Avatar
Default smokey
I had that problem with my ED after i did a service once, and after a couple of days it just seemed to stop smoking, although i don't know if this is a good thing or not,
Either way i'm hoping it won't do it again, once i chuck a tickford head on it.
Can anyone tell me if it's worth while to put in a ED XR6 ECU on once i fit the Tickford head???
Or should i just stick with my normal ECU???
EdFairmontGhia is offline   Reply With Quote Multi-Quote with this Post
Old 26-01-2007, 03:41 PM   #11
Xplode0185
Xplode0185's Avatar
it is not smokey anymore so i would say it was to mutch oil dosent matter now anyway he just brought a ef futura 145,000 km for $3,840 good price i thought
Old 26-01-2007, 04:13 PM   #12
LUXO_8
windsor user
does he want to sell the ed? what kind of $?
Old 26-01-2007, 11:19 PM   #13
Xplode0185
Xplode0185's Avatar
na he is keeping it but im looking at selling my ed xr6
