Hi all
Can someone tell me the difference between these BOSCH PART No 0280150775 BLUE TOPS and standard injectors. Thanks for any answers in advance. |
DJR TM#54
What type of car do you have?
Injectors have different colours depending on there flow rate.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went. Now Zetec Powered. 1.6lt of madness. But the XR8 still remains ![]() |
sorry i have a 1999 au forte
Back on the road
The 0280150775 are an EV1 injector that where fitted OEM to 4-cyl Magna's and 5.7L HSV's.
They are bigger than the std AU injectors, and pretty sure they have the same connector tye (Jetronic), so they would be a bolt-in deal. Why are you looking for bigger injectors for your AU?
------------------------------------------------------------------------- AU XR8 Ute 13.90 @ 100mph - http://www.aufalcon.com/xr8ute 5L Windsor, GT40X heads, Crane 2030, Pacey 4-1s, Lukey 3", 3.91:1, auto. Tuned by me w/Quarterhorse and BinaryEditor. Coming Soon: Ported lower intake, Tickford "Premium" Brakes, and a good wash. |
I just saw them on ebay and mine need cleaning.
So I thought it might be a cheap option. What are the standard ones ? and what other cars are they the same as. |
Back on the road
Definitely would not be a cheap option. You would need to get your computer retuned...
I would be getting any second-hand set of injectors cleaned and flow checked before fitting them anyway. According to here, http://apps.bosch.com.au/products/sa...rservparts.pdf, your injectors have this part number, 0 280 155 844. That part number only appears for six cylinder AU Falcons/Fairlanes/LTD's.
thankyou
My AU has a rough idle. Which gets worse if idling for a frew minutes.
It also has a fuel smell if idling with A/C on and the A/C cuts in. |
