Low and Loud
I recently Picked up my Mum a '88 Series 1 EA fairmont ghia. The Problem im having atm is I cant start it!!!
The car appears to have a factory alarm system? There is a sticker on the rear door Quarter that says "MOTOCRAFT ALARM fitted" The thing seems to be into everything and when it was purchased from auction it didnt have the beeper. How do i disable it? When I try to start it the alarm makes the headlights & indicators flash. thanks guys
1993 Ford Fairlane NC3 Silver - LTD mockup, Worked V8 & Auto, Fully Optioned, Half of my Audio department at work installed in the car 1993 Ford Falcon XR6 Poly Green Stationwagon - 4.0 I6, Auto, 3:45LSD, All the usual XR6 Stuff but in a wagon ![]() |
02/90 EA II Fairmont
go over the wiring on the ignition etc, track down the alarm and trace the wires, it will have relays that intercept/cut the starter etc...
211RWKW EA |
if its an old alarm it's probably got the siren and module contained in the one unit under the bonnet. All alarms are different, but try and trace the wires back inside the car and see if they go anywhere near the ignition barrel. Check to see if the Red/black wire is cut somewhere and spliced into the alarm loom. If it is, cut those wires off and join the red/black back together. That's your starter wire.
Otherwise, use a test light to probe the wires at the back of the alarm module while an assistant turns the key to 'start'. You should find that one of the wires will illuminate the test light when the car is turned to start. Now usually this wire will have a 'brother' that either is the same colour or diameter....join those two together and that will bypass the start immob. Hope it helps. |
Low and Loud
Well its all sorted out now..
Turned out the Original Factory Alarm had another newer style immobiliser wired into the back of it, and some other box wiried into that on top! the drivers side kickpannel was full of Alarm Junk! Simply Cut the negatives to the alarm, Removed the wiring off the Steering column and its all fine Thanks for the help people ![]()
Last warning
does it start now mick???
FALCN6 - Turbo, Air Bag Suspension - Hibernating EL GT - Supercharged NASCAR - 83 Thunderbird , Bagged DAILY - BA Fairlane Ghia, Boss 260 Turbo OFFROADER - Ford Explorer ![]() |
Low and Loud
Oh Yea! Took it for a drive last night, Went sideways and all around corners, Mmm LSD
Drives really well actually
Last warning
great to hear, bargain!
#8 | |||
not here much anymore
2024 F150 XLT
#9 | |||
Low and Loud
Rider on the storm
Hey do you have a `CrocLock' sticker under the hood? I've got one on my EA, but I have nfi what it does (must've been disconnected or something)...
Low and Loud
Nope, Mine says "HI GUARD ALARM by Motocraft"
#12 | ||
haha as in
"Hi, Guard this alarm; if anyone touches it, it will become inneffective"
211RWKW EA |
Tha Stah
lol
too true haha
1998 EL XR6: |Custom POD Filter Intake, Pacemaker 4499's, Redback 2.5" Catback - straight through tail pipe.|. 113,000kms. Best E/T: |15.080 @ 91.03mph | R/T: 0.848 | 60': 2.175 | 660': 9.674 | Colour: |Regency Red.|. Soon To Come: |Largish Cam + Chip| ETA: *When the bank account is ready * ![]() |
#14 | ||
They actually put alarms in ea's as a factory thing??
My car had some sort of alarm aftermarket 'pirranah' brand or something. it caused a few probs when we removed the dash to put the manual pedle box in simply because the wiring was threaded through the other looms. so we ripped it all out. I think it must have been a really cheap one because the car didn't start afterwe got it back together and all that was wrong was the fuel pump wiring needed to be fixed. I guess you could have done the ben trick and wired it to a brake light if you wanted to steal the carlol.
