Old 12-02-2007, 05:02 PM   #1
Orbit
Resident Nyctophobic!!
Orbit's Avatar
Default squeaky diff?
noticing going around sharpish right and corners a sharp squeak seems to be coming from the diff area....any ideas?
Orbits secret to life: Eat less, move more!
Orbit is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2007, 05:59 PM   #2
Burley
CRE.87V
sounds like wat mine did....had to get something replaced in diff....but wen i drove straight the diff wanted to pull me off the road....got it done under nrma wen got car fixed..cost them 500 to fix
hope thios helps
Burley is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 08:03 AM   #3
Orbit
Orbit's Avatar
anyone else want to offer an opinion?
Old 16-02-2007, 08:28 AM   #4
bodes-sh
have you tried changing the oil?
Old 16-02-2007, 08:59 AM   #5
JoesAu
JoesAu's Avatar
i get a squeak wen u put it in to D, i think its my brakes not sure.
JoesAu is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 12:39 PM   #6
Dark Horse
_Oo===oO_
Dark Horse's Avatar
Not your handbrake?
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 01:20 PM   #7
Orbit
Orbit's Avatar
hmmm very similar noise to teh handbrake...and ford did adjust it recently.... would it be the case only one certian corners if it is teh handbrake?
Old 16-02-2007, 01:24 PM   #8
EBTom
EBTom's Avatar
On a particular sharp right-hand corner near my house, the same things happens to my car, except my squeak is more of a thump/bang followed by the engine instantly dropping to idle and then suddenly springing back to life as normal.
Search was hopeless so im also inerested to see the replies.
EBTom is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 01:50 PM   #9
AU dude
Flying high...
AU dude's Avatar
yea that squeaking noise is the rear brake calipers. there is a bit of movement in them for some reason. if you have the wheel off the car or can get ur hand on to the caliper, try forcing them to move and u'll hear that squeaking noise. i fixed it by getting a 15mm spanner and gave them a nip up...
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel,
3" mandrel intake, K&N pod in the box, Polished Rocker Cover.
AU dude is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 02:11 PM   #10
AU dude
Flying high...
AU dude's Avatar
but i also get a grinding/squeaking noise from the part were the handbrake line connects to the back part of the brake rotor but my handbrake needs to be adjusted as it sometime locks the wheels on the last click...
