Old 16-02-2007, 11:48 AM   #1
nikos
mezzo forte
Default Clickety click?
Hi guys n gals
When I do a cold start, I get a clickety-clickety kinda noise coming from the motor. After about 30-60 seconds it fades away. When still cold, and I rev the motor, the noise disappears and then occurs again when the revs reach idle level, but only for a couple of seconds usually.
I was guessing maybe an idle bearing as the noise ceases when revved? Or if not that, the time before enough oil reaches the top of the motor?
Although the other day I walked past an el as it started up, and I think I heard the same noise. Is it common? Or serious?
Thanks in advance
nikos is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 12:39 PM   #2
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
if you heard it in an EL , it must be Serious
AU2PWR
AU2PWR is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 12:42 PM   #3
SSVPom
Formally FairmontPom
My VCT Ghia does the same when cold, usually only for as long as it takes to back out of the driveway, then it goes.
I have no idea what it is, probably something connected to the serpentine belt, ie, tensioner or alternator or one of the powersteering/water/aircon components.
Thats a fat lot of help to you isn't it?
SSVPom is online now   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 05:15 PM   #4
Mechan1k
Mechan1k's Avatar
Might be lifters ... then again it could be a number of things though.
Old 16-02-2007, 06:44 PM   #5
AUTickford
XD197
AUTickford's Avatar
Wtf is an idle bearing, could it be related to a lumpy idler gear hahaha No but seriously man its a low oil pressure, lifter or internal problem which cant be fixed without a rebuild.Exact same thing on my v8 and battens told me only a rebuild will get rid of the noise.My motor runs fine and doesnt burn oil but is friggin noisy at startup,lack of servicing will do it. Just service your car more regularly now and use an additive to quieten it down.well u can do the lifters without a rebuild but they would probably be noisy all the time if it was them.
AUTickford is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 07:34 PM   #6
bodes-sh
it could still be lifters, it could also that the w rating of the oil is too thick, try putting engine oil flush through it next time you change the oil, then put some lifter free and tune up in with the new oil and see how it goes
Old 16-02-2007, 07:40 PM   #7
OZFORDAU
OZFORDAU's Avatar
Tappets maybe?
OZFORDAU is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2007, 08:51 PM   #8
rayner22
rayner22's Avatar
Sounds like the old AU 6 rattle to me... ur not the only one with it mate.
Kinetic FGX XR8
Old Rides:
BF MkII 07 XR6 , Seduce in colour.... : Growler Airbox, custom exhaust and other goodies
AUII TE-FORTE
Monsoon Blue,Full Cobra Performance exhaust system, G+D CAI, Crow Cam, Tickford Suspension, TE50 Kit, RDA Slotteds, Ridin on Advanti 18's
rayner22 is offline   Reply With Quote Multi-Quote with this Post
Old 17-02-2007, 12:31 AM   #9
AU2PWR
Spin 'em Habib !
AU2PWR's Avatar
the Rattle that shows the I6 is Still Alive and ready for More Abuse , 95% sure its going to be Low Oil Pressure
AU2PWR
Old 17-02-2007, 12:30 PM   #10
nikos
mezzo forte
Thanks guys. I might ask my mech what grade oil was used on the last change.
Old 18-02-2007, 02:17 PM   #11
rayner22
rayner22's Avatar
ur probly best using a 0w-40 or something like that, thats what im using. rattle is now only at startup
Kinetic FGX XR8
Old Rides:
AUII TE-FORTE
Old 19-02-2007, 02:00 PM   #12
xertia
xertia's Avatar
Hehe, I noticed the same on mine when I bought it. I even took it back to dealer and they said it sounded normal, Its a very quiet rattle on mine that clack clacks when you rev and then dissipates. I figure its normal, I've had the car almost 3 years now and the sound is still there and no worse than when I bought it.
xertia is offline   Reply With Quote Multi-Quote with this Post
