Old 18-02-2007, 03:01 PM   #1
futura
futura's Avatar
Default Walbro Fuel Pumps
Is there a Walbro Fuel Pump available for a El falcon 4L??
If not, what type of fuel pumps are peolple using??
futura is offline   Reply With Quote Multi-Quote with this Post
Old 18-02-2007, 03:05 PM   #2
LUXO_8
windsor user
http://www.fordforums.com.au/showthread.php?t=68396
unless your car is a late EL, it should have the same carrier as my car.....
Old 18-02-2007, 04:36 PM   #3
futura
futura's Avatar
My car was the last of the EL's, but the carrier should be the same. Thanks for the guidance MADNC 8. Will post some pics when I get mine done.
Old 18-02-2007, 04:37 PM   #4
LUXO_8
windsor user
mmmm...im pretty sure the last of the EL's got the AU style carrier.
Old 18-02-2007, 05:25 PM   #5
futura
futura's Avatar
If thats the case, then has anyone fiited a Walbro pump to an AU style carrier?
Old 18-02-2007, 05:31 PM   #6
LUXO_8
windsor user
yep!..
in my thread, the guy jimt3te50 has just fitted one to his T series
Old 18-02-2007, 05:39 PM   #7
futura
futura's Avatar
How much $ do the walbro pumps retail at??
Old 18-02-2007, 07:44 PM   #8
LUXO_8
windsor user
i paid 140od for mine off ebay, you have to be careful though as the copy's are quite close looking to the genuine pumps.
Old 18-02-2007, 11:25 PM   #9
needfordspeed
I paid $155 (delivered) for mine, it's an intank one which was good for around 5-600HP IIRC, they're very easy to install.
1988 EA S-Pack|MPI|LSD|AIT turbo manifold|Garrett GT3540|3" Exhaust turbo back|Cooler|Sports ryder shocks|Pedders lows|Resprayed|Microtech LT8s|60lb Injectors|Bosch 044 with surge tank|3000 RPM stall|Ported AU head|Turbo grind cam|Crow double valve springs|1.3mm MLS headgasket|C4 Conversion|Built bottom end|Custom plenum|10.6@125MPH
needfordspeed is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2007, 01:17 PM   #10
BLKPHN
ORSM FORD CRUSIERS
BLKPHN's Avatar
walbros are great, i had one on the EB when it was turbo and nevr gave me any trouble, and they are cheaper than the stock ford units!
BLUEPOWER RACING DEVELOPMENTS
Strive for perfection in everything we do. Take the best that exists and make it better.
When it does not exist, design it. Accept nothing nearly right or good enough.
-[BLKPHN] (VIC) PLATES FOR SALE $495.00-
BLKPHN is offline   Reply With Quote Multi-Quote with this Post
Old 19-02-2007, 04:15 PM   #11
futura
futura's Avatar
Ford are asking $232.90 for a standard replacement pump, makes the Walbro even more attractive.
