Old 13-03-2007, 12:32 PM   #1
hoich
hoich's Avatar
Default Tyre Wear AUII XR8
Hi,
I have noticed that the inside edge of all four tyres have worn badly and need replacing. Is this a common thing? The tyres have only done 28,000 km.
Hoich
2016 MD Mondeo Titanium Hatch
hoich is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2007, 12:41 PM   #2
JefXR8
JefXR8's Avatar
Thats ok k's for me,but it does sound like a decent wheel alignment is needed.
JefXR8 is offline   Reply With Quote Multi-Quote with this Post
Old 13-03-2007, 12:49 PM   #3
blackers10
blackers10's Avatar
just make sure you take it to a place that does camber and castor
as most small time tyre shops that do"alignments" only do toe adjustment
Old 14-03-2007, 01:19 PM   #4
AU dude
Flying high...
AU dude's Avatar
You may need to purchase a camber castor kit, especially if your car has be lowered, or hit a few gutters which changes your alignment...
AU1 Forte - 17'' AU2 Tickford rims on all corners, Super low springs,
KYB shock absorbs + camber castor kit and a 3.45 LSD, Tickford snorkel,
3" mandrel intake, K&N pod in the box, Polished Rocker Cover.
AU dude is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2007, 02:15 PM   #5
nikos
mezzo forte
Sounds like you've lowered without adjusting camber?
nikos is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2007, 03:55 PM   #6
hoich
hoich's Avatar
Hi guys,
Thanks for the tips. Car hasn't been lowered.
Hoich
Old 15-03-2007, 04:07 PM   #7
Dark Horse
_Oo===oO_
Dark Horse's Avatar
If the alignment is done correctly as blackers10 has pointed out you shouldn't need a camber kit.
Dark Horse is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2007, 05:09 PM   #8
Autocade
Originally Posted by hoich
Hi,
Hoich
Exactly same happened to my XR6 VCT
They could not adjust front camber enough to stop excessive inside front tyre wear & Ford told me to take a hike
Fitted a pedders camber caster kit and got a quality alignment same time & has been perfect to 73000 ks
Make sure you get a print out of the alignment readings as they have the recomended settings on them
Autocade
Autocade is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2007, 12:38 PM   #9
hoich
hoich's Avatar
Thanks for the tips Autocade.
I have booked my car in at pedders for Thursday.
Hoich
