Old 16-03-2007, 10:50 PM   #1
blackers10
blackers10's Avatar
Default clips too short to fit skirts?
i am mid way thru fitting my BA side skirts
and my clips seem to be too short? to hold the skirt AND rubber seal on...
and how the hell do they attach to the underbody??
thanks guys
Old 17-03-2007, 12:03 AM   #2
JC
JC's Avatar
I had the same issue. Ended up using some black self tapping screws instead, and drilled them into the rubber, then the skirt, then the body. Being black, they are hidden by the rubber.
Ford Performance Club ACT
Old 17-03-2007, 12:05 AM   #3
blackers10
blackers10's Avatar
oh REALLY
might give bunnings a visit then!!
no trouble with water getting in or wind noise from the seal?
or has the seal"sprung" back up around the screw causing it to be perfectly fine??
thanks JC! much appreciated
Old 17-03-2007, 12:14 AM   #4
JC
JC's Avatar
Originally Posted by blackers10
oh REALLY
I'll get a photo for you to show you roughly where to put the screws so that it holds the rubber strip down, and so it's not visible once the doors are closed. To help with sealing, I dipped the screws in silicon sealant (selleys all clear, IIRC), just to ensure that no unwanted moisture gets in under the sills.
Old 17-03-2007, 12:25 AM   #5
JC
JC's Avatar
Photo below. I used 7 screws all up. They are little black mushroom head ones - around 8g or 10g by 12mm.
Old 17-03-2007, 12:31 AM   #6
blackers10
blackers10's Avatar
thanks mate!! big help!!
skirts tommorow WOOT!!
Old 19-03-2007, 06:00 PM   #7
Hords
Treasure your balls?
Hords's Avatar
Blackers,
I had the same trouble fitting AU2/3 skirts to my AU1. Ended up getting longer clips from Ford. The AU1s have just enough plastic protruding to attach the seal strip only. The AU2/3 clips make an allowance for skirt thickness. The other difference is there are 2 more clip retaining holes in the AU1s. So I had to drill and slot two more slots on the skirts. The clips were less than $2 each from memory (sorry, turfed the receipt). If going this way put the new clips in the seal strip lining 'em up with the appropriate slots in the sill and skirt. A lot easier than putting the clips in the sill, skirt over the top and trying to clip the seal strip over the top.
Rob
Meteorite T3 TS50 ESS
Hords is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2007, 06:02 PM   #8
Hords
Hords's Avatar
Forgot to mention there's another black metal clip that's used to mount underneath. 4 a side is sufficient.
Old 19-03-2007, 06:26 PM   #9
blackers10
blackers10's Avatar
sall good.. self tappers saved the day YAY lol
Old 19-03-2007, 07:05 PM   #10
JC
JC's Avatar
Need pics then!
Old 19-03-2007, 07:08 PM   #11
blackers10
blackers10's Avatar
here ya go
need some better pics but they get the idea accross!!
Old 19-03-2007, 10:20 PM   #12
au2sw
Blown 5L coming
au2sw's Avatar
i have to say blackers, it looks good, cannt wait to see the rest of the lower skirts on the front and rear bars done the same colour, reckon it'll look smick!!
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;)
NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com
Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com
Originally Posted by Mr Hardware
Its like central locking in your car. We've all had cars without it and we were fine then, but try and take it from me? NO WAY.
au2sw is offline   Reply With Quote Multi-Quote with this Post
Old 19-03-2007, 10:28 PM   #13
HLC
Audi S3
your car isnt low enough blackers :P
skirts will look mint with the rear on/mouth
Old 19-03-2007, 11:47 PM   #14
auvct
auvct's Avatar
that looks sweet mate!
Are you fitting the rear tl bar as well?
www.theretrofitsource.com
auvct is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2007, 03:01 AM   #15
AUIII XR8 MAN
DJR TM#54
AUIII XR8 MAN's Avatar
Skirts look good, but the colour not to my taste.
When traveling to V8 Supercar rounds, i book through KYLEE MOLE Travel agents, She Goes, She Goes, She Goes & I just went.
Now Zetec Powered. 1.6lt of madness. But the XR8 still remains
AUIII XR8 MAN is offline   Reply With Quote Multi-Quote with this Post
Old 20-03-2007, 09:51 AM   #16
TheSneakiness
Adapt or perish...
TheSneakiness's Avatar
I gave it the thumbs up on Sunday. I really like the look of it.
Carless
Old 20-03-2007, 06:24 PM   #17
blackers10
blackers10's Avatar
yes i am fitting the TL rear skirt
just need to get it painted up and fitted(its a genuine plastic item)
