Old 01-04-2007, 04:18 AM   #1
hans1
Default Tire Question - Focus Mk 1
I have a question from the USA:
On the Mark 1 (old body) Focus, the optional 7-spoke 17" x 7" wheel in Europe came with a 215/40 tire, but I hear in Australia it came with a 215/45. Is this correct?
Also, what was the final drive (axle) ratio in the Mark 1 2.0 Zetec 5-speed in Australia?
Thanks.
hans1 is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2007, 09:21 AM   #2
FOCUSonTHIS
FOCUSonTHIS's Avatar
Yeah the optional 17" MP3 wheel on the Australian Focus came out with 215/45 tyres
The final drive ratio for the Zetec is 4.06
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 01-04-2007, 02:39 PM   #3
hans1
Thanks for the info. That 4.06 is the same as in Europe. In the US, the 2.0 Zetec was unfortunately specced with a rather long-legged 3.82
Old 01-04-2007, 04:59 PM   #4
zetec
Zoom Zoom
zetec's Avatar
To be honest, I'd prefer the 3.82, the LR Zetec is geared too short for economy. It's not exactly bad at an average of about 8.0-9.0l/100km, but it could be better for a 2.0 litre hatch. I don't need to do 0-100 every day in 8 seconds, I'd rather better fuel consumption - the thing's screaming at over 3,000rpm at 1000km/h. I'd rather it sat at about 2,700rpm just below the power band so it would use less and simply require a single downshift for power.
My 2c anyway. I love it, it's perfectly balanced, but my only real criticism after 4 years is it could be a little more fuel efficient with the help of a slightly longer final drive ratio. I don't know how the europeans with their high speeds could handle the 4.06!
2012 Mazda3 MPS
zetec is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2007, 06:58 PM   #5
FOCUSonTHIS
Dunno about you, but my car has never reached 1000km/h. But if it was sitting at 3,000rpm I would be happy lol
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 01-04-2007, 10:10 PM   #6
1lifeliveit
Focus is my middle name
1lifeliveit's Avatar
Think abt the torque and the power curves...1000kmph at 3000rpm.... :hihi:
2004 LR Ford Focus Zetec
3 door, Panther Black, Manual, 17" MP3 Alloys, SVT Airbox with K&N panel filter, SVT Snorkel, Leather Gear Knob and Steel Handbrake Cover, ST170 pedals, ST170 Lower grille, CFM UDP
Not too soon : Focus sport/Borla Exhaust, Throttle body
1lifeliveit is offline   Reply With Quote Multi-Quote with this Post
Old 01-04-2007, 11:16 PM   #7
Martyvan
Martyvan's Avatar
Dont know about the others, but I havnt actually tried to get to 1000kph, Im sure Matt has given it his best shot though. Hahaha!
I would personally prefer a slightly taller ratio, My Corolla at 100kph sits on 2350rpm which is good... Its the only reason we take the Corolla on long trips... the Focus screams too much... :O
Martyvan is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2007, 12:17 AM   #8
zetec
Zoom Zoom
zetec's Avatar
Don't knock it until you try it. The power band goes from 3,300rpm to 5,500rpm and then hits a wall. It is usually around the time that the Prandtl-Glauert singularity occurs when I hit transonic speeds above Mach 0.8, roughly 1,000km/h but I think the wall I hit is due to the aerodynamics of the Focus just not being made for speeds greater than that.
I've tried for Mach 1.0 and greater down that hill heading southbound on the F3 from Gosford just coming into Hornsby, but just never made it close enough to break the sound barrier. I am yet to try it with the newly installed ST170 grille and 17" rims... :dj:
Here's a pic of me on my last attempt.
2012 Mazda3 MPS
Old 02-04-2007, 07:55 AM   #9
Marshy79
hahahaha gold!
Marshy79 is offline   Reply With Quote Multi-Quote with this Post
Old 02-04-2007, 08:49 AM   #10
melbzetec
Old enough to know better
melbzetec's Avatar
Matt can do it because he has a 3 door. 5 door apparently is not as capable.
Old 02-04-2007, 10:58 AM   #11
1lifeliveit
hahahaha nice comeback
Old 02-04-2007, 06:48 PM   #12
FOCUSonTHIS
Worst photshop I have come across but 10 for effort
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 02-04-2007, 10:12 PM   #13
fordel
Tricolore Tard
Contributing Member
fordel's Avatar
ST170 Rims, will make you hit Mach 1.5 no worries ;)
fordel is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2007, 05:50 AM   #14
hans1
How is the ride quality of the standard Zetec 2.0 on the 215/45-17's? I am thinking of upgrading from my OEM 195/60-15's.
Old 03-04-2007, 07:44 AM   #15
melbzetec
melbzetec's Avatar
It's the only size rim I've ever had on my Focus, but I find the ride terrific
Old 03-04-2007, 08:52 AM   #16
zetec
Zoom Zoom
zetec's Avatar
Ride is brilliant, however I also have full ST170 shock absorbers and springs, so it's slightly harder but still outstanding. On standard suspension, not a problem either.
2012 Mazda3 MPS
Old 03-04-2007, 08:54 AM   #17
FRA
Mr Focus
FRA's Avatar
Its alot better to drive with then the 15".
I have Maxxis tyres on our hatch 215/45/17's $165each
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody
Oz racing: WRC OBX: 4-2-1 race header
SCT: xcal3, dash scan.
FRA is offline   Reply With Quote Multi-Quote with this Post
Old 03-04-2007, 10:45 AM   #18
1lifeliveit
It'll definitely feel a little harder in the beginning. But soon u'll get used to it and will never go back. The steering will become a touch harder as well. But Im sure ull never complain
Old 03-04-2007, 03:51 PM   #19
hans1
OK, I think I am going to get some 17" wheels and the 215/45's. One final question - what pressure did Ford recommend for these tires? (The USA had no 17" option for the 2.0 Zetec)
Old 03-04-2007, 04:32 PM   #20
FOCUSonTHIS
32psi
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
Old 03-04-2007, 10:39 PM   #21
zetec
Zoom Zoom
zetec's Avatar
32psi recommended, run them on 38psi for best handling/tyre life. Less understeer.
Manufacturers ALWAYS bias towards comfort.
2012 Mazda3 MPS
Old 04-04-2007, 02:00 PM   #22
Martyvan
Martyvan's Avatar
Ive only got the standard 16" rims on my zetec, but i still run between 38 and 40 PSI, usually 1 higher at the front....
