26-04-2007, 07:22 PM | #1 | ||
Spin 'em Habib !
Does the Plastic Trim above the Airbag on the Passenger side come off ?
AU2PWR |
26-04-2007, 07:34 PM | #2 | |||
Blown 5L coming
the trim you talk about is the spear im assuming, and yes it does come off, as to how, i wouldnt be 100% sure i think there is a couple of bolts, maybe otherwise it would be a couple of clips.
1995 EF Fairmont was stocko 6cyl with open single spin diff....NOW WITH XR8 ENGINE, DRIVELINE AND SUSPENSION!!!!! Maybe by the end of 2010 there may just be a blower as well ;) NEW CLUB FOR SUNSHINE COAST !! www.f-p-e.proboards.com Contact Col (au2sw) via PM or on MSN @ efmonty@hotmail.com Quote:
26-04-2007, 07:35 PM | #3 | ||
FTF Club Moderator
It does come off. In order to get to it you need to take the airbag out and you will see the screws holding it in IIRC.
Albert Einstein: Es ist schwieriger, eine vorgefaßte Meinung zu zertrümmern als ein Atom. (It is more difficult to alter a preconception than split an atom) Falcon Tickford FPV (FTF) Car Club of NSW Fords in the Park 2010 I use and recommend Stingray Car Security. http://www.stingraycar.com.au/ |
26-04-2007, 07:46 PM | #4 | ||
Spin 'em Habib !
meh , Screw that .. excuse the pun
AU2PWR |
26-04-2007, 07:55 PM | #5 | ||
If you plan on removing the airbag cover first check if it has the break upon removal clips which cannot be reused, unless you are lucky.
26-04-2007, 08:33 PM | #6 | ||
CRE.87V
u need to pull out the air bag..get flat blade screw driver and pry bottom out...these are one way clips....they are bout 10 bucks to replace from ford....there are 4 or 5 10 mm nuts...undo these then it will pretty well fall out
26-04-2007, 08:34 PM | #7 | ||
How about if you don't have a airbag there.... whats under it?
26-04-2007, 11:14 PM | #8 | |||
27-04-2007, 01:27 AM | #9 | ||
Don't worry bout the passenger i want a TV too, :
Wouldn't be a bad place to put some gauges. |
27-04-2007, 10:25 AM | #10 | |||
27-04-2007, 11:09 AM | #11 | ||
Built Ford Tough
The way to access those bolts, without removing the airbag, involves removing the center console, and cover to the side of the dash, and using a long arm. It's not recommended though, and if you try that like me and drop a nut, you end up removing the airbag anyway...
Dunno about those clips being $10 though. I bought 8 (in case I had to do the job again) and it was lucky to be a couple of $$.
Black on white '83 SWB F100 C6 auto 351C on gas and on the ground --> Project Thread '55 F100, just a roller at the moment, new project Silver MY12 Volkswagen Amarok |
27-04-2007, 11:21 AM | #12 | |||
OLD SKOOL BABY
XB Sedan - Trick Mansweto built 351 3V Alloy Headed Cleveland,Demon Carby ontop of CHI Hi Rise Manifold - 600HP 83 F100 XLT - 351 Cleveland C6 Auto wrapped in Black snake skin vinyl, daily tow rig.1976 XB GS COUPE (waiting to start the rebuild)
27-04-2007, 06:10 PM | #13 | |||
27-04-2007, 06:21 PM | #14 | ||
not here much anymore
Those gauges on the passenger side of the dash look bloody awful!!!
2024 F150 XLT
27-04-2007, 07:22 PM | #15 | ||
CRE.87V
only need 4 clips cost me 9 bucks on trade from ford....the whole cover is like 57 on trade....there is a bit of space behind it but it looks crap so u would have to mod it to make a storage space
